bucket1032
- Nov 11, 2021
Hello all,
Picked up a 2020 ecodiesel limited w/ 12k miles as a certified pre-owned about a month ago. I went looking under the hood for the block heater cable yesterday and found something weird. On the passenger side of the engine, towards the firewall and near the top I found a piece of cloth which might be exhaust wrap, but its the smoothest feeling exhaust wrap I've ever felt.
It's ziptied to some part of the engine that's under a rubber cover. Not the main plastic cover but a softer rubber cover that's a bit lower down and towards the passenger side.
I'm a little concerned as its doesn't look like something that came from the factory. Pics attached. First one shows general area where it is (under/behind the coolant bottle, you can see a white material if your eye follows straight down from the cap). Second pic is a close up of what it is.
Any ideas what it is and if I should take it for service or inspection?
