Shoot, I noticed a little over spray from the LineX
I wouldn't. It's black on black... No one but you will know it's there.Its on the plastic part below the sliding window, there was a tiny amount on the glass, that was easy to remove. I'd be nervous trying to scrape it off plastic with a razor blade
The instructions KRField posted are spot on. I've used a razor blade on paint in the exact same manner to remove really stubborn contaminants that clay wouldn't get off. Just follow the instructions, be gentle, and you'll be fine.Its on the plastic part below the sliding window, there was a tiny amount on the glass, that was easy to remove. I'd be nervous trying to scrape it off plastic with a razor blade
