Ft level suggestions
Tattoofever6971
Massachusetts
So I have a 2020 ram 1500 4x4
I put the rough country level kit in the truck been awhile but it’s the one that gives aprox 3 in the ft and 1 in the rear with the new control arms and rear shocks
That was perfect until I found out the rear springs just can’t handle the weight of logs I haul to split
So I upgraded the rear springs to a heavy duty set which are perfect for the weight but now got that high rear end again
I took out the rear 1” spacers that came with kit helped a little
The spring company sells a heavy duty ft spring that advertise it will take away the stock rake
So if you made it this far
Has anyone changed out the ft springs with heavy duty and done the 3” level kit I guess I’m just worried about being to high in the ft or putting to much stress on the upper ball joint even though I’ve replaced the control arms when I did the spacers
Or brake line issues etc
