Front license plate bracket
rv6392
2019 RAM, Anyone else with issues mounting front license plate? Hardware provided seems to just spin in the mounting holes. How have you resolved?
borant
I search now for 3/8x1" self taping screws. Common license plate screws are 1/4x3/4
RT70808
I don’t require a front plate, I’ve been trying to decide what to put in those predriled holes!
202snowman
5thGenRams Supporter
Rochester, NY
Dealer just mounted mine and it didn't indicate any issues
alacombe
Mine was already mounted when i got my truck. Just have your dealer do it
borant
Dealer will not tell you that screw is barely holding with half turn tension :)
sticker500
I thought about painting some Christmas trees fasteners and pushing them in there.
rv6392
Ended up using larger hardware. 3/8x 1.5 had laying around. Seems to work ok. Not the sturdiest mount though. Thanks for the feedback.
RT70808
I’m leaning towards some of those lugnut / chariot spikes the truckers are using!
WRH
Same problem here. Plus, the holes drilled were not lined up. Real lame.
Craftman
Orange County California
Mine was installed when I picked up the truck. - So might as well use it - Looks better without it but you don't see it when your driving.:giggle:
alow
Yeah I did the install and didnt like the free spin. I'll look into some of the bolts you guys suggested, thanks
ryelinek
I put mine on and no issues with it at all. Couldn’t wait to get the Temp tags off and get my real plates transferred back over. It’s not that difficult to figure out but bonus points for anyone that understand my plates.
RT70808
Winner winner (y)
It was too easy, northern Virginia full of military, don’t tread license plate and if you’re going to buy a kimber in .45 it’s going to be a 1911
DawnKileyAndrea
I thought I had the same issue with the screws not being long enough for the front license plate, as well. However, the piece on the back of the holder that the screws go into should be lined up and pushed into the holes of the bumper first. Then the screws are inserted, expanding the plastic and holding the plate in place. Mine is holding very well and firmly now. Also I know I'm months late to this conversation but I'm hoping it'll help someone else trying to find a solution.
slimchance
lancaster, pa
i put the front plate and bracket on MY truck using the supplied stuff and did NOT have any problems .. screws are tight
Bhbdvm
western NC
After mounted, do you have to get some more screws to attach the plate?
