Front & back outlets not enough juice
Dodgehemi0
So I have a Laramie everything but air suspension in it. I have 2 3 prong plugs one up front and one on the back center console. I took a 1k mike trip and the plugs don’t have enough juice to charge iPads? I’m using the 20w wall chargers for the iPads to. My ford I had was able to charge both of them just fine. Am I missing something in the 2019 Rams? They say 115v on the plug covers in the truck. Anyone have this issue?
TruckDriver
California
same usb cable in both cases?
if it's not the OEM cable (or 'certified lightening') i've seen apple products will charge slow,even with the oem charger but non-oem cable.
like said above though, if it's all oem, is it tripping the circuit/blowing a fuse? that'd be a dealer visit for sure
Dodgehemi0
Cables aren’t oems however the same cables charged just fine in the f150.
Dodgehemi0
They should be able to handle both I pads no problem. Have you checked to see if they have power going to them at all?
There is power because the cables have lights to show it does have power.
Diamondback
Midwest
There's definitely an issue, because each outlet in the ram is rated at 400 watts. iPad chargers are 12 watts and 10 watts, respectively. Take it to the dealer.
Incorrect : ALL outlets SHARE upto 400 watts .. not 400 watts each. (1 inverter to all outlets)
but still, 20 watts between 2 outlets SHOULD work .. I'd just the cable if it is Apple authentic.
RamCares
Michigan
Hey Dodgehemi0,
I certainly understand why this would be concerning. Given what you’re experiencing, I kindly recommend connecting with your local Ram dealer for a diagnostic appointment. Our team is available via private message if you are in need of any assistance with that process.
Mark
Ram Social Care Specialist
TruckDriver
California
fair enough - if it worked in one it should work the same in the other... makes me wonder if the inverter in the ram or f150 are pure sine wave vs modified sine; that makes a difference with the charging brick (and other devices).
I'd definitely give an OEM cable a shot or even just another cable, the LED cables are notorious for robbing power while charging
thabiiighomie
Cincinnati, OH
Stupid question. The outlets are rated 115 V AC 400W.
Does this mean I cannot charge my Ryobi batteries in the truck?
The charger states: input 120V ~ 60Hz 80W.
Thanks!
Diamondback
Midwest
Thanks!
Yes -- 80W is less than 400W .. (REMEMBER: that is 400 W divided by 3 outlets if you want to use more than 1)
mine charges great with the small USB
What? USB in a 115V outlet? are you using the 115vAC-to-5vDC adapter? I've never seen a Ryobi charge via a USB .. must be new tech.
Neurobit
RAM Sorcerer
Texas
He mentioned "small" USB, I think perhaps he's talking about the USB-C port (maybe).
thabiiighomie
Cincinnati, OH
There is a new port for USB on Ryobi 40V battery chargers.
Diamondback
Midwest
Crazy! How long does it take to charge? Longer than normal battery charger I presume/assume?
I was going to use my RAMBOX 115V to charge my UAS (aka Drone) batteries myself.
