First fuel fill up
Beatle9999
I need to fill up my eco-boost for the first time. Im new to diesel so I’m not sure how to go about this. So there’s renewable diesel, diesel #2. Then I’m reading about additives like diesel kleen and stanadyne. What do you guys recommend?? Should the additives be added at every fill up?? I’m in Southern California, lots of highway city street driving. I have a new 2021 ecodiesel. First time diesel owner so don’t wanna mess it up.
AMS Guru
AMS Guru, Ram Guru-ish
Eastern Iowa
My opinion no additives, no biodiesel. Just #2 from reputable fuel stations that receive regular transports. Change fuel filter per OM schedule. Engine oil changes very important to use MS-12991with Magneti Marelli filters. Avoid short trips as much as possible. Welcome to the EcoDiesel family I have loved all of mine!!!
NorthStar
Texas
Dump the Ecoboost and get a real truck - an Ecodiesel! 😉
Seriously, I’m 100% with AMS Guru except for the fact I’m a believer in using Stanadyne or Hot Shots for lubricity and anti-gelling in extreme cold - but to each their own. Also, I recommend monitoring regens via MX+ or similar so you can ensure you NEVER shut down or during a regen. IMHO all of this is called maintenance and failing to maintain a diesel isn’t like when I was younger…you could beat the heck out of them and they kept running. With the EPA crap on them, beating and failing to maintain will cost you dearly.
J-Cooz
Try and go to busy stations so you know you're getting good fuel.
Also take a second before each fill and make sure you're actually at the diesel pump. It sounds stupid you want to make sure you don't accidentally put gasoline in while not paying attention.
AMS Guru
Eastern Iowa
I agree with additives in winter 100%. I just went with the fact he's in SoCal so never any cold.
jmt8706
Michigan
I've always used Power Service products in the diesel I owned. Add a gray bottle every few fill ups to keep things lubricated. ULSD doesn't have a lot of lubricity.
Beatle9999
Thanks for all the help!! Gonna go fill her up, 4.29 a gallon here in SoCal.
JGRaider
I"ve posted this before..........I was in the fuel business for 25+ years. At a particular terminal, there's no difference in diesel fuels amongst the "brands", as all "brands" are the same unbranded diesel that is either shipped up the pipeline, or refined, then stored in huge bulk tanks. When loading the fuel at the terminal you designate which supplier you are buying from (Shell, Chevron, etc) but it all comes from the same bulk storage tank. MSDS sheets are readily available when loading, and every diesel fuel from that terminal or refinery is the same spec.
All ULSD fuels are lacking in lubricity and cetane nowadays, which is why I use and recommend additives. I personally use Hot Shot EDT or OptiLube. You may not notice increased mpg, etc, but lubricity is enhanced, and a really good thing.
JC4041
Rosamond, CA
Where at in SoCal? I filled up @ 4.07 on base (Edwards) Friday, but in town it's crazy. I don't even want to see what it is in Lancaster/Palmdale.
alamgirian6329
I can hear the clatter difference when I dont put in EDT and LX4 combo after my fuel fill-up. I have run them in my truck since new.
I have done mixed driving but alot of highway. In my 15 months or so, I have put 30,000 worry free miles on my truck - so never really worried about Regens, even with shorter trips because I always end up on highway sooner or later to make up for them.
myles
honestly I just treat all of my diesels like a normal car, just fill up with #2, no additives.
AdamChandler
Lebanon, NH
1. Interstate-side-diesel
2. EDT from hotShot every fill up
3. DEF @ the pump (for convenience)
4. Oil / filters changed on time and keep records
that's all I plan on doing.
NorthStar
Texas
doesnt ram car take care of the first 3=4 oil changes and maintenace
Ram Care is only available for Rams sold in Texas.
