Can you add the factory trailer brake controller to a truck that didn't come with this option? Is the wiring there so it's plug and play?
I had it added on my 2019 laramie and works just as it should. I am not sure if anything below laramie would for sure have the wiring or not tho.Can you add the factory trailer brake controller to a truck that didn't come with this option? Is the wiring there so it's plug and play?
Added mine myself to my Bighorn and all the wires are there taped up. To the OP, you must then have the computer flashed.I had it added on my 2019 laramie and works just as it should. I am not sure if anything below laramie would for sure have the wiring or not tho.
