ETorque/Battery problem
Lesjim
2021 RAM 1500 3.6L v6 ETorque Normally the battery voltage indicates 14.3 volts while charging/traveling. After a1400 mile trip,I was checking the voltage indication and it showed 13.6 volts. As I continued, the voltage progressively decreased to 13.3. It never recovered to its normal 14.3. No indicator lites. I checked the battery stopped after I disconnected the battery cables and it indicated 13.3. I am traveling and am concerned about continuing the trip. Anyone have any suggestions? Thank you for any help.
Lesjim
...It's above 12v...
I know that 12.6 volts is a fully charged battery but I have never seen the voltage level any less than 14.3 volts with the engine running. I am not that conversant with the ETorque system. Possibly the charge level decreases if the battery is fully charged. I hope that this is the case. I am trying to get a more experienced person to chime in and confirm that there is no problem.
Dirk Diggler
I’m pretty sure it’s normal. Your battery is charged enough as you’re driving it for a longer distance than usual. The system reduces the charge rate to prevent overcharging.
Lesjim
Thank you for your response. As I continued my trip I found that the voltage fluctuations were normal.
