country4life
- Jan 20, 2021
hi i accidentally drove in 4wd high for about 10minutes in my 2020 ram 1500 sport is it ok?
I try to do that about once a month when the road is straight just to keep everything lubed .hi i accidentally drove in 4wd high for about 10minutes in my 2020 ram 1500 sport is it ok?
I do the same thing. I drive out of my neighborhood in 4hi every month. it's about .5 miles and has one turn.I try to do that about once a month when the road is straight just to keep everything lubed .
Sounds right but I don't have 4WD auto .You should be able to use 4 auto for that, no? Even if 4wd doesn't actually engage in auto while driving straight on pavement, I believe the only thing that isn't working (as opposed to 4hi) is the clutch isn't engaged, but everything else WRT 4wd should be turning?
4WD should only be used in low-traction situations. So if that parking space is dry pavement the steering problem is caused by the nut behind the steering wheel.I feel like I was an idiot for buying my 2020 Ram 3500 Dually with it's sluggish 4-wheel drive. You just CAN'T steer the wheel in 4WD more than about 1/4 turn left or right withot incurring binding and bucking from under the hood. Negotiatiing a parking space is fruitless.
Is there a relatively cheap fix? A recall? A 4wd removal Kit? An aftermarket add-on? Virgin Sacrifice? What SHOULD I have purchased? For $80+ G's, I really expected more.
3500 HD Dually w/ HO Cummins, 3.73 Rear End, 6-speed AISIN
Longhorn Limited (loaded); we pull a 35 ft, 15,000 lb. 5th wheel. Effortlessly.
As long a it's in a straight line.
No other complaints, really, but, this WAS my first rodeo, and I apparently blew it.
i agree but i accidentally bumped my 4wd hi button when leaving home depot and drove through the parking lot made 2 turns no problem before realizing haha had the dealer check it over nothing is wrong with it for short distance won't hurt anything! and possibly the 2020 ram has a saftey feature to not engage when on dry payment even though i was in 4wd hi in was blinking on the dash letting me know... you would have to drive for at least 30-45minutes to wear out anythingYou should never be using 4wd on pavement and/or parking lots. Put it in 2wd and the bucking will go away.
so you don't think driving out of home depot in 4wd hi and making 2 turns damaged anything my dealer says its fineI try to do that about once a month when the road is straight just to keep everything lubed .
No I don’t think you damaged anything . I only use it on dry pavement when in a straight line but a couple turns by accident won’t hurt it and if it did you’d know it .so you don't think driving out of home depot in 4wd hi and making 2 turns damaged anything my dealer says its fine
and the light was blinking on the dash i think the 2020 has a feature where it detects to not go into 4wd when dry pavement as the
