DEF Useage
Rhombus
Cedar Park, TX
Just put 3100 miles on my 2020 Bighorn. Mostly highway miles. The truck used 1/2 tank of DEF. This is MUCH more than I used on my 2014 Ecodiesel. Just curious what others are seeing? Thanks.
Seaeco
2500 miles with just under a half a tank used.
WXman
Kentucky, USA
Under what conditions does the truck use more DEF? Driving unloaded and taking it easy, or working the engine hard?
rorischak
Pennsylvania
Also, where is everyone purchasing their DEF? I have bought from Amazon but I am sure there has to be another way. My guess is that if I stop at one of the large truck stops I can pick some up.
alamgirian6329
I have used 3/4 of the original factory filled DEF at about 2900 miles.
According to dealership Service Manager, the truck will use *Most* amount of DEF when idling. He obviously recommended Mopar DEF, but then proceeded to stay, Blue DEF at walmart would be fine - as long as its not an old product (fresh stock).
tyresmoker
Exact same with mine.
NC Rebel
1/4 used at 1300 miles, should see over 5000 when full.
WXman
Kentucky, USA
Walmart here locally has their own brand of DEF that's $8 for 2.5 gallons so that's not bad. Appears to have the same certification markings on the package as the Peak name brand stuff. Also, says it has a shelf life of at least 12 months, so no harm in stocking up a little.
The_Dude
You guys can go to a nearby truck stop and fill up. Your local pilot for example.
PolarXJ
I've almost got 2,000 miles on mine and it has used about 3/8 of a tank.
NAPA auto parts had a sale on DEF last week $7.49 for 2.5 gallon jugs.
Sascwatch
I have a total of ~4200km on my truck now and after this weekends long road trip I was below 1/2 of a tank of DEF. I added 2 gallons and it is just about full now.
myles
9k miles on my truck, seems to get about 5k miles or so
Emg006
Has anyone have their def level fluctuate? I was driving after a dealer visit was over 1/4 tanks, then it dips into red, went up, back down-a couple times, now it’s just under 1/4 and no movement sense.
NC Rebel
My def gauge stays pretty consistent, haven't noticed anything like you mention. I have noticed that my volt meter drops a little low when driving but comes back up to normal when I decel for some reason.
Sascwatch
I noticed the def level fluctuating by about 1/4 tank after returning home from the north. It would go from just below half to below 1/4, I think it had something to do with the extreme cold I was in the 2 days before. I added 2 gallons and it holds steady now.
RamCares
Michigan
Hi @Emg006 - if you decide to address this with your dealer, please be sure to let us know via PM!
Mark
RamCares
