My truck wouldn’t start a few days ago so I attempted to jump it with a jump box with no luck. I had to manually disengage the transmission into neutral so I could push my truck back out of the parking spot to jump it from my 5500. It started right up but now the A/C doesn’t blow cold, the check engine light is on along with electronic stability control light, and to top it off the truck won’t shift out of 1st gear (I’ve tried to shift manually via the gear shift buttons with no luck) any ideas? 2.5 years old 2019 Ram 1500 Laramie 4x4 19,500 miles.
* when I attached the jump box I notice that the antilock brake vacuum pump was continuously cycling on and off possibly draining the battery. I unplugged it multiple times from the pigtail connection with no luck
