Is that 76” in entry mode or normal parked height? Thanks!Just went out and measured mine for you. Stock 22s with stock tires. 76 inches from the ground to to top on the satellite shark fin antenna.
If your in entry exit and you put it in drive it automatically raises to aero mode...pretty sure, just got a longhorn and it seem to do that when i put it into drive.Anyone know the clearance at the lowest level. Just sold my TRX as my new condo has a low garage and I can’t park inside. I still want a ram and was hoping the limited will fit with suspension set as entry exit. Thx
Entry/Exit. Give or take an inch for driveway not being perfectly level.Is that 76” in entry mode or normal parked height? Thanks!
