Ceramic Pro Gold lifetime package
The6lugplug
Just got my truck back from the detailer after 3 days of impatiently waiting and I'm absolutely blown away by the results!!! The ceramic pro coating really makes the tri-coat pearl pop like I've never seen before and makes the paint feel and look like glass!!! If your near the Bakersfield,CA area highly recommended detailed detailers. Can't wait to try out the master blaster air dryer I picked up too. Hopefully the water just Flys off and won't have to towel much. Anyone have any tips or recommendations for cleaning a truck after ceramic coating? This is my first vehicle with the coating done.
SkeeterRAM
Fayetteville NC
Ask them. Went to a local shop and they will provide a "How to Wash Your Truck" to make sure I don't mess it up. As in never go thru an automatic wash. Brushless maybe, just as long as nothing touches your truck. You Tube has plenty to offer. There is a thread on exterior that covers your question. I'm also looking at a coating that will make the paint pop. Fella said they could do 10year however the 3year is the one to make it POP. With proper care should be able to get 5years, so sez the professional, that will provide the car wash training. What soap you use (PH), even the towels. Can't wait for class. Gonna get new buckets and everything :)
Good luck. Nice looking truck.
Cajun_
Louisiana
2 bucket method, using a foam cannon and a pressure washer around 1k psi is best. don't use anything with wax in it and try to stay PH neutral. name of the game is use anything with extremely high lubricity if that's a word. Use chemicals to do the hard work for you. w8v2 bug remover, chemical water spot removers (i use adams for this), always use a drying aid. I like OG drying aid from Obsessed garage these days but adams quick detailer and xtream solutions topper works as well. Anything you can do to reduce the amount of time you touch the truck. I personally also use two different microfiber mits, One for the top half of the truck and another for the bumpers and rocker panels. And don't touch the truck for a week or two if possible after you got it back. Use a shampoo without any additives in it like adams car shampoo after 72 hours and that's it.
cervelo15
Lehigh Valley, PA
You’re not only going to love how good it looks, but the time you save cleaning. Ceramic coating takes a multi day process and cuts it down to a couple hours (Could be a little more if you’re OCD like me)
The6lugplug
Thanks for all the great info! really appreciate the support! i did pick up 3 bottles of the ceramic pro after care ill pick up some of these other products as well to help with the cleaning process.
bigdodge
Happy Ram Owner
this is the same company that did my truck.
I use chemical guys wash and no rinse and microfiber towels to dry it off. takes about 6 towels to dry truck.
got it off amazon.
I have a small spray bottle of the cleaner in the truck for bird crap with a microfiber towel
SnowBlaZR2
Fuel Economy Champion
FL
So, I didn't coat this truck yet. I might not with how happy I am with the Griot's stuff I'm currently testing.
On my car that is coated, including the wheels, this is my process:
Wheels first. I have a dedicated bucket and assorted brushes.
  • Rinse with pressure washer.
  • Foam cannon application of P&S Brake Buster on wheels, tires, and fender wells. Let that dwell for a minute or so.
  • Scrub fender wells, tires, and agitate wheels.
  • Rinse, apply GYEON Wet Coat, rinse again.
Paint next.
  • Foam cannon application of Chemical Guys Snow Foam (Honeydew). Rinse and apply again. As soon as I'm done here, I hit the emblems and other tight spaces with a soft brush.
  • Hand wash. I use two buckets, but not traditionally. One bucket is soap and the other is empty. I use 8 wash pads doing a panel at a time. When I'm done, the used mitt goes in the empty bucket and I grab a fresh one for the next panel.
Dry
  • Dry with MetroVac (don't forget the wheels). This gets most of the water off and out of door sills, mirrors, etc.
  • Spray on a drying aid (recently switched to Griot's Ceramic Speed Shine) a panel at a time and dry. I use the Gaunlet towels (30x36 and wheel towel) from The Rag Company.
Glass and Trim
  • I like Invisible Glass.
  • Box method with glass towels from The Rag Company.
  • Hit the trim and tires with Chemical Guys VRP.
Then I move on to the interior. As needed, I'll also give the engine bay and undercarriage a good cleaning before I do the paint.
If it's a hot, sunny day, I'll do this in the shop. If it's cloudy and cool, I always prefer to wash my vehicles outside.
There's probably some other things I do but forgot, and this is my process for my maintenance wash.
bigdodge
Happy Ram Owner
another thread here
JaylonW
Paint next.
Dry
Glass and Trim
I typically follow the same process after my ceramic coat ... my biggest issue is true no sling tire shine. Any suggestions?
SnowBlaZR2
FL
Haven't had any issues with VRP slinging.
Also going to try out the Optimum Opti-Bond gel.
cervelo15
Lehigh Valley, PA
Try the new TurtleWax Graphene tire shine….it has a matte finish and doesn’t sling the tire shine all over the place after applying. It actually dries in 5 mins
