Bellpa
Does anyone else have an annoying squeak when they rest their elbow on the rear portion of the center console? I have the Laramie full console.
Yes. Dropped my truck at the dealer on Wednesday, and that was one of the issues. They are replacing the console lid (and adding freon, swapping LED ambient lighting around glovebox, and hopefully swapping brake pads for the squeal). Should know later if it will be ready this afternoon.Does anyone else have an annoying squeak when they rest their elbow on the rear portion of the center console? I have the Laramie full console.
Yeah, this is what I did. Wasn't about to take it there just of that (or the ambient lighting issue), but since I had a list of things, I went ahead and had them all done at once.Nice. I'll add to my list for the first oil change. Thanks.
It seems like the brake issue is hit or miss with people as far as getting it fixed, some say the dealer tells them that a different factory pad doesn't exist. What is your experience did they acknowledge that a different pad design exists, it would be nice if Ram would release a TSB for the different brake pads.Yes. Dropped my truck at the dealer on Wednesday, and that was one of the issues. They are replacing the console lid (and adding freon, swapping LED ambient lighting around glovebox, and hopefully swapping brake pads for the squeal). Should know later if it will be ready this afternoon.
IDK yet. Just heard from my service advisor and they're currently replacing the center console and LED strip since they got the replacement parts this morning. From there it goes to the brake technician so I will post back once I talk to him again this evening.It seems like the brake issue is hit or miss with people as far as getting it fixed, some say the dealer tells them that a different factory pad exists. What is your experience did they acknowledge that a different pad design exists, it would be nice if Ram would release a TSB for the different brake pads.
Which squeak returned? Console or brakes?I had my console lid replaced. Took about a month to get the lid but that was back in april. Also the limited lid is specific. I had front pads and rotors installed and the squeak returned shortly after though
Three fist pounds and just like that, the squeak is gone. Thanks for the tip.Probably not the best solution, but I just banged on my with my fist a couple times and it went away.
Happy to help!Three fist pounds and just like that, the squeak is gone. Thanks for the tip.
Yeah, so happy I got mine replaced. Mine squeaked really bad with the slightest pressure.My console has the same annoying squeak. Doesn't bother me as much as my wife. I'm not so sure I want to be beating on it to "fix" it though. I am glad to hear some are getting it replaced and that works. I will be bringing this up at my first oil change also, thanks for the info.
