I picked up a Catch Can on Amazon for $54. I have some M20x1.5 to 3/8 NPT adapters coming for it.
Fittings:
The Authority in OEM Quality and Affordable Powersports Replacement Parts. Shop with confidence. Guaranteed fit, backed by a lifetime warranty.
www.highflowfuel.com
Note there are three spots that are not drilled and tapped for the top screws. The Side port is the inlet
and the top port is the outlet. There is also a plug on the bottom that you can also fit a Valve with hose
for emptying the reservior.
With the average daily temp below freezing here in NH, I have to wait to do all the Modifications to
the truck, Including the AUX Fuel Tank for the Bed, Switches, Wiring, On Board Air System, Nathan
K5LA Train Horns, etc. On top of the truck cost I have spent another $7500 in Accessories.
