CarPlay will not work
Matty2010
My CarPlay stopped coming up as an option and when checking the USB sources all it says is USB ERROR even when the cable is not connected. Any tips for getting this fixed?
TheDutchRAM
The Netherlands
Do you have an iPhone? Running on the latest IOS version?
Also try to change the setting to enable USB accessories under Touch ID and Access Code settings. That worked for me.
Neurobit
RAM Sorcerer
Texas
It may be coincidence. That setting does not include CarPlay, which will independently ask if you want to allow when locked, regardless of the setting you mentioned.
More than likely it's the USB hub. It's a known issue which a lot of us here have. In my case, all USB ports stop working at the same time, I know this because it also happens to my music thumb drive.
TheDutchRAM
The Netherlands
Yeah might be. For some reason Carplay stopped working for me and this was the fix. Maybe the pending IOS update was causing trouble.
in this case a faulty USB hub might be the culprit indeed.
Matty2010
Im thinking that probably is my issue also. I have an appointment on Monday to have it checked and replaced. Thanks for the reply!
Matty2010
Got it squared away. Dealer had to do a factory reset on my head unit to get the USB ports back to functional, then installed available updates. Only took five and a half hours.
