Cargo Divider without RAM boxes on 22 limited
JaylonW
2 questions...
1. Can i get the cargo divider that turns to the extender if i dont have ram boxes and a BUG installed.
2. If i get the cargo divider that attaches to the BUG rails, can i get the medal bed extender as well?
Thanks
mikeru82
The Palouse
2 questions...
Not sure if you're asking about the rambox bed divider/extender. There will be no way of attaching it to a non-rambox bed.
I'm not familiar with the non-rambox bed divider but I can't see any reason why it wouldn't work with a flip style bed extender, like the one AMP makes...
Deke
I am having a similar issue. I have a 2022 Limited with bed utility group and the ram tonneau cover without ram boxes. Apparently there is no cargo divider that fits this configuration. I can't believe ram doesn't make a divider that would attach to the tie downs that are on the rails. There is apparently a cargo divider available from ram for the existing rails, but it won't work if there is a tonneau. The dealer is checking to see if there are any aftermarket options available. The popular roll n lock ones won't work with the tonneau either. Sadly I think I am going to end up buying an adjustable cargo bar from walmart. That will work for bigger items like boxes, bowling/golf bags, etc. Doesn't do much for like grocery bags and smaller things. My buddy is a master welder and does a lot of custom fabrication work. I might have him look at it and see if he can come up with something.
tob1y2k7
New Jersey
Hi, I just installing the rough country tonneau cover and cargo divider, it need a small modification but if your friend is a welder he could definitely do clean job then me lol, see the link below. I hope this helps.
JaylonW
I got the backflip cover and gave away the tonneau cover...the BUG rails still fit fine. I gave up on the divider and got the ram bed extender. Im good.
wegasque
Goodyear, AZ
Did the Mopar Cargo Divider not work for you? I've got the BUG and MFT with no tonneau and the website says it'll work for my truck. Installation instructions look like it would too.
Wilsonwanderings
Did anyone answer this question? I'd love to not have things slide to the front every time I use the brakes. Have the factory tire down rails and the X4 tonneau.
