What is the best riding 34 or 35 inch al terrain tire for a 22 inch rim? I once accidentally put a load range E tire on my Jeep and the ride really suffered.
I have been happy with my BF Goodrich All Terrain T/A K02s. Granted I have the 20s but the tread should be the same. Most of the guys on here that are running the Nittos or the BF Goodrich tires have had good luck. I had the Nitto Terra Grapplers on my F150 and I liked them as well. As long as you stay away from load E as you said, you should be fine.
You might as well forget it. The best wheel size is 17”. However for the 5th gen you have to do do 18”. The tires flex on the sidewall. With a 22” wheel you have hardly any sidewall. I’m running a 70 aspect ratio. I want a lot of sidewall. I’m waiting on Carli Suspension to get the 5th lifts ready. Once they do I’ll eventually get another set that’s a 75 aspect ratio. And the next thing is look at how much YOUR truck weighs and use tire load ratings to determine what psi you should be.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
