I wonder if this is only the case because of our larger diameter wheel bearings. Couldn’t we just purchase the required set of wheel bearings to go with these spindles?
I seriously doubt that these wheel bearing aren’t interchangeable. I’m willing to bet the axels are the same, regardless of wheel size.
Unfortunately, the cost of using BellTech would then be higher due to the added cost of new wheel bearings over IHC’s kit but I have a gut feeling that BellTech’s will ride better than IHC’s because you’ll retain factory bushings and the tie rods wouldn’t cry for mercy. My opinion, It’s worth a try.
