Bed weep holes
Txd33r
Are there drain holes supposed to be in the bed? Mine fills up with water every time it rains. Just wondering if they got filled up with bed liner.
MannymanX
5thGenRams Supporter
AzZona
Yeah, my bed liner filled the drain holes in my bed too... I have a cover so i don't care about it but i can see why it's a problem for you.
SD Rebel
San Diego, CA
There is on the back side, mine drained just fine even though I have the factory spray-in liner. However, they can easily be filled up with debris over time. You need to clear them out if it's no longer draining.
STR
Yes, the bed has drain holes near the cab. My bed has the factory spay-in liner, and I can still see daylight between some of the panels near the tailgate too. It would have to rain pretty hard for a long time to gather any measurable water. I agree w/above... the holes are probably filled w/debris.
Txd33r
I’ll check that out. I bought a peragon cover so won’t be an issue much longer.
