Anyone else have this problem
JE25
I have a 19 bighorn and when I got ready for work this afternoon I noticed that the headliner in the back had water stains on it. It rained about an inch in my area last night.
Has anyone had any problems with something leaking towards the back of the cab?
ElkoNV
My dog thinks I’m cool.
NV
Welcome to the forum! Sorry, you got the dreaded leak, there is another thread here as well:
mikeru82
5thGenRams Supporter
The Palouse
Could also be the 3rd brake light leaking. Have you recently removed the 3rd brake light?
SD Rebel
San Diego, CA
Based on the photo, I don't see any cracks, likely a 3rd brake light leak. Easy to fix with better seal you can buy at home depot.
JE25
Thank y’all for the info. No I haven’t done anything to the 3rd brake light. I noticed some very small water stains the last time it rained but honestly never gave it much thought. Today was a different story!
Do y’all think I could use some silicone around the light cover?
SD Rebel
San Diego, CA
The oem seal is puny, gets smaller and harder as rubber does over time which leads to the leak. This is a common leak on many trucks. Remove the lens and you can see what kind of seal you need, then go to Home Depot and buy some, preferably slightly thicker. Get the seal that already has a single side of adhesive tape, which you will trim for fit and install on the 3rd brake light.
If you add sealant, make sure to add it to just on the seal where it makes contact with the body. I wouldn't try to "seal in" the light itself, just the rubber seal.
Here is a good vid on how to do it, it's on the previous gen, but similar:
JE25
Awesome, thanks again, I appreciate it
Ramman_666
Just had same issue. We have a full 90 page thread in it call dealer ASAP get fixed. 3rd break light and see if you have any cracks in the sides of the plastic top window frame next to the center window.
