Another Spacer Thread
kmblackbear
Alrighty, so I've pretty much set my mind on BORA spacers.
Couple questions, I'm running the stock rims and tires for now and probably will be for awhile, maybe a year-ish. I'm thinking of 2" spacers in the back, 1.5" in the front or maybe 2" all the way around. Does anyone have pics of a '19 Rebel with stock rims/tires and either of these spacer setups?
Also, is there any rubbing going either setup?
How much clearance do you have?
And yes, I have the Air Suspension too.
In a year or so I am thinking of tackling new rims/tires but have no idea what I would go with, maybe 35's and a 4" lift? But for now I'd like to make the stance a little better with the stock.
clazer
The BORAs are good. If you want even track width front and rear, the rears need to be .25” thicker (0.5” total). Factory rear track width is 0.4” skinnier than front. I went with 1.25 and 1.5. That puts the sidewall outside the factory flares but not the tread. Details and pics in here: https://5thgenrams.com/community/threads/the-journey-toward-a-bigger-rebel.12301/
also look at the sticky in wheels/tires section on modifying the front fender well for better clearance.
