I checked the battery today about an hour after my wife brought the truck back in, 12.53 which was surprisingly low. I put it on the charger as I’ve seen Several of the the battery charts for sealed lead acid as needing to be at either 12.6+ or 12.7 to be 100% charged.
Advance Auto Parts says this:
WHAT IS THE IDEAL CAR BATTERY VOLTAGE YOU CAN HAVE?
Measuring your car battery’s voltage can be a great way to determine how charged your battery might be. The ideal car battery voltage range will provide you with a relevant interval according to which you can measure precisely what the voltage says about the battery’s current charge. A perfect voltage with the engine running is between 13.7 and 14.7V. With the engine off, you should get a reading of 12.6 volts. If the battery isn’t fully charged, it will diminish to 12.4V at 75%, 12V when it’s only operating at 25%, and down to 11.9V when it’s completely discharged. This data and the way it relates to the design of your battery should provide you with some useful insight into the functioning capacity of your car battery.
here’s another: (slightly higher voltage)
State of Charge | Sealed or Flooded Lead Acid battery voltage | Gel battery voltage | AGM battery voltage |
100% | 12.70+ | 12.85+ | 12.80+ |
75% | 12.40 | 12.65 | 12.60 |
50% | 12.20 | 12.35 | 12.30 |
