How did you go about moving them up?I moved mine up about half way closer to the plastic than yours are. No issues
Loosen the clamp holding them onto the exhaust. It's located about fifteen inches or so in from the end of the tip. With the clamp loose, move it to where you want it and re-tighten the clamp. Be sure to hold it in the position you want while tightening or it could move on you.How did you go about moving them up?
Yup, this. Very easyLoosen the clamp holding them onto the exhaust. It's located about fifteen inches or so in from the end of the tip. With the clamp loose, move it to where you want it and re-tighten the clamp. Be sure to hold it in the position you want while tightening or it could move on you.
Looks great. Thanks for the pics.No issues whatsoever... been like that for over 4 months... looks much better...
The left side is the "before"
Much appreciated. Wish I had known this sooner cause I would have definitely done that. Looks so much better. Tomorrow morning I install a Borla S-type exhaust so we will see how much adjusting I need to do for that.Loosen the clamp holding them onto the exhaust. It's located about fifteen inches or so in from the end of the tip. With the clamp loose, move it to where you want it and re-tighten the clamp. Be sure to hold it in the position you want while tightening or it could move on you.
