Your instincts are correct sir, he’s not telling the truth. I show over a hundred Laramies with air suspension within 150 miles of my location... perhaps you can find one in your area at a more honest dealership? Here’s the inventory website for Ram, just put your zip code in and select your most important options. It will show you nearby matches. Good luck.Has any one received a Laramie with air ride? Dealer says he can not order one. Does not sound right. The Ram site has it.
Not available on Tradesman.For the 2019 Ram, the Active Level Four-Corner Air Suspension is standard on Limited and optional onall other trim levels..
Steve
That information is from an order guide that shows Tradesman has Air Suspension as an option.Not available on Tradesman.
Well I apologize for questioning the honesty of your dealer then in this case. Given what @BobbiBigWheels and others have said, hopefully the restriction is just a temporary one. The Laramie normally offers air suspension as an option, so they are out there now that way on lots, and maybe you’ll be able to order a custom one soon. Good luck.The option stopped last Sunday. Have not found out the reason yet. I went to several dealers today none could order the air ride except on the Long Horn. It comes standard on the Limited.
