flowmotions
- Feb 27, 2021
Im resorting a 2019 Classic 1500. I bought it for cheap so it requires a bit of work. There is 2 Airbags that have gone off in the car . ( both on the passenger side ) front seat airbag and curtain airbag. I also will need to replace the seatbelt tensioners and im assuming the airbag module will need to be reset. Any info or advise would be appreciated on how to DYI it. I could do it for cheap if 2015 airbags are compatible with the 2019 model as they are the same body style aswell as internal trim and many other similarities
2019 1500 Classic 5,7l
4x4
Quad Cab.
ST internal Trim
4x4
Quad Cab.
ST internal Trim
