Aftermarket amp power wire install
Hackmunch
For all the audiophiles. When you ran the power wire to the rear. How did you run it? Someone had said there is a gromet in the rear you can enter from underneath? For rear 48v battery?
You could run it underneath the sill plates, thats where a factory harness is ran.
The easiest way I saw and the way I did it was through the grommet used for the ebrake cable. Once through popped off the lower trim and ran it to the back.
