Add Auxiliary Camera and Trailer tire pressure monitoring system
Ron D.
does any one know what the part number would be auxiliary Camera with 12-pin connector from Mopar. I have 2019 Ram 3500 Laramie 4X4 8' bed with Cummins High Output with 4C nav with 12" display.
Does your truck have the 12 pin/7pin plug?
We are having a debate on HDRAMS.COM about this.
The part number is available, but no part yet.
No, just the 7pin. Could not find out how to order it with 12/7 pin
Thanks. That seems to be the situation everyone is in.
We found the kit and the numbers, butScreenshot_20190428-195723_Samsung Internet.jpg
Check this out. I am guessing this is what you did and it wasn't there.
Yes, what is the part # for the tire pressure part and does that work wireless?
Thanks for all your help, Your GREAT!!!
The part number is listed over at HD Rams. I will see if I can find it. It is the same as the one for the truck...and yes it would be wireless.
I am guessing maybe you found the display?
PART NUMBER...68433188AA
Discussion at HD RAMS
I ordered TPMS , Ram Trailer Camera Vehicle Prep Kit and Camera. They said it should ship by 6/15/19 for my 3500. Thanks again for all your help!!!
Where did you order these parts from, and what are the part numbers, and what are the costs? Thanks.
Is the trailer camera only mounted inside the trailer or can it be used on the back of the trailer for better visibility backing up?
