7507 LED Turn Signal Bulb factory
classiii
Name:7507 BAU15S Amber LED Bulb
Product Introduction:
Introducing the 78-SMD 3014 series LED turn signal replacement, it is surrounded with industry-leading 78-chip of SMD-3014 to launch full scope of amber light and equipped with optical lens on top for strong light penetration.
Product Specifications:
Product features:
Full Scope of Light: we NEVER sacrifice the materials! 78-chip of SMD-3014 line up to deliver 360 degree light pattern and light up every corner in reflector cup.
Optical Lens: The focusing lens on the top of bulb, creates a more focused and penetrated light beam, and offers a stylish look to car or motorcycle turn signal.
Our Advantage:
Distinguished quality: To stand out in competition, we are committed to develop innovative and high-quality products as our core competence.
Our service:
1.For e-commerce owner, we offer free material folder including product designed pictures and description, then you can ease the work of product uploading.
2.Each season, our R&D team is capable of launching at least 4-5 new market-oriented products, we can regionally allow one client to exclusively sell the newly released product.
Our certificate:
Route101 have successfully passed the certifications such as CE, E-mark, RoHS for Euro market, and DOT for United States market to help oversea clients with hassle-free import.
Our Package:
There are three options of packing our products, which are separately anti-static bag, blister and box. By default, we use neutral pack and optionally route101 branded pack. For OEM/ODM brand owners, customized logo package is also available.
Our payment:
Route101 has partnered with globally well-known payment providers, such as West Union, Paypal, and bank transfer (T/T) is also available. Full payment for small or trial order; 30% T/T in advance as deposit, and 70% before delivery, for bulk order. We will show you the pictures of goods ready before your payment being cleared.
Our Shipping:
Route101 has deeply cooperated with global air freight carrier such as TNT, DHL, UPS, Fedex, EMS and more to have higher discount rate and lower shipping cost. Or we could also deliver by client鈥檚 partnered air or sea freight carrier.
We have most of items stock available, the delivery time of small order is efficiently shortened to be 2-5 days, and of the bulk order is 5-15 days.
The car high beam does not light up
The car's high-beam headlights do not turn on. Frequently encountered failures include: dead car battery, headlights burned out, and headlight assembly damage.
The power line before the headlight switch is short-circuited, the fuse in the headlight circuit trips or burns out, the bimetallic contact of the headlight switch is poor, or the switch is damaged. In most cases, the car鈥檚 battery is dead, which will affect the car鈥檚 inability to start. , Insufficient car battery affects the headlights do not turn on. You can also press the horn or flip the signal light switch to test. If the horn sounds or the turn signal is on, it means that the fuse power cord is normal. Therefore, you can use wire test or power short connection method to test the ammeter terminal, ignition switch terminal, Follow the sequence to detect whether there is a short circuit in the light switch terminal. If the circuit is normal, it means that the headlight switch may be damaged. The brightness of the two lights of the car headlights is different, one is bright and the other is dim. Most of this situation is that the headlight reflector is dusty or oxidized, and the dim light connector is loose or rusted, which increases the resistance.7507 LED Turn Signal Bulb factory
website:http://www.101route.com/led-turn-signal-bulb/7507-led-turn-signal-bulb/
Still doesn't fix the CANBUS or HYPERFLASH issues on older cars.
Malodave
