5th Gen Ram - Additional Lift
jdaugherty
Does anyone know if you can increase the existing Air Suspension Lift in the 19 Ram Limited? I really like the ability to remotely raise or lower my Ram but would like to get a little more distance from the ground.
this will help you.. https://5thgenrams.com/community/threads/why-not-just-add-a-spacer-to-level-the-air-suspension.1774/
Readily available option is aftermarket "leveling links" which trick the air ride sensors into thinking the height of the truck is too low so it will lift the truck. But this makes the ride stiffer (driving in OR1 and OR2). Going too high will trigger trouble codes and towing issues. https://www.revelperformance.com/li...ustable-air-leveling-links-set-of-four-links/
BDS apparently is working on a 4" kit but nothing actually confirmed.
Unexplored option is to add lift spacers but the leveling links will need to be adjusted, but no one has tried this yet on 2019 to my knowledge. This video is only the front, but theoretically you could do something similar to lift the rear but no one knows for sure. Also need to consider other components (brake lines, air ride supply lines, etc.)
No members online now.
