barr0208
I think he means since his last oil change lol
Update: Added the 1/2 quart to top it off before my 1100 mile trip towing our travel trailer. Checked oil level at the end of the trip, nothing was consumed.625 miles on my truck. Checked all fluids for the first time in preparation for an 1100 mile trip. Engine oil was a half quart below full. Maybe a low fill from the factory? I’ll keep an eye on it.
I have 18000 miles on my 2019 Ram 1500 5.7 L engine. Bought in July of 2018 and have had all service calls at dealership. I notice that about half way through my engine oil life and when I check the engine oil level, I end up adding 3 quarts. I usually check the level every 3000 miles. Nothing burning. Is this normal to burn through about 4 quarts of oil in 10,000 miles? I had a Chevy big block that you had to check every fill up because that large of an engine used oil.
Next timee I take it in I am going to have it checked. I already had the top end engine seal replaced under warranty. Hoping I did not buy too early in the 5th gen before bugs were worked out.
Update Aug 20, 2019...Vehicle continues to use about 1 Qt every 750 miles. some soot, no leaks. Dealership is conducting oil consumption test and will return vehicle at 1100 mile mark. Five other 2019 Ram 5.7 Hemi owners stated they use maybe one quart per 8000 miles. Will be looking at early work conducted by dealership to repair issue with cylinder/valve. Maintaining all documentation, and maintaining a professional dialog with dealership. I have 25k on vehicle and think it is warranties for 36k.
Also documenting a known issue before your 36000, if it’s left unfixed/resolved is coveredThe bumper to bumper warranty is 36K, but powertrain is extended 60K.
In other words, anything non-engine or tranny related needs to be fixed before 36K, but you have a lot more time on your engine / tranny / Diff.
Update 10 September, dropped off last week to analyze oil consumption after 1100 miles. Came back one quart used in 1000 miles and dealership stated it was within standards. Came to pick it up today and brought with me the FCA engine bulletin provided by Jv77. Service bulletin 09-007-18 states one quart per 2000 miles is norm. They just Informed me I would get another rental car and they will keep truck for more tests. I wonder what will happen?If you end up going into the dealer for a diagnosis, let us know. Our team is available via direct message and can get you an additional layer of assistance while working with the dealer.
Jasmine
Ram Social Care Specialist
Update on sept 10th. Oil consumption test completed and 1 qt at 1000 miles. Service acceptable consumption based on VIN engine report. I came I and provided FCA service bulletin 13-007-18 that says all gas engines should be less than 1 qt per 2000 miles. The decided to keep truck for further test and called back my rental car. Wonder what will happen. They did not know sbout the bulletinI have 18000 miles on my 2019 Ram 1500 5.7 L engine. Bought in July of 2018 and have had all service calls at dealership. I notice that about half way through my engine oil life and when I check the engine oil level, I end up adding 3 quarts. I usually check the level every 3000 miles. Nothing burning. Is this normal to burn through about 4 quarts of oil in 10,000 miles? I had a Chevy big block that you had to check every fill up becasue that large of an engine used oil.
Next timie I take it in I am going to have it checked. I already had the top end engine seal replaced under warranty. Hoping I did not buy too early in the 5th gen before bugs were worked out.
I did and provided update. Hopefully it can be resolved.If you end up going into the dealer for a diagnosis, let us know. Our team is available via direct message and can get you an additional layer of assistance while working with the dealer.
Jasmine
All repaired and back on road. It had to have engine replaced due to some type of ring issue. Ram did a great job.Hi jkgray22,
If you'd like an additional layer of assistance while your truck is in service, please follow up with us via private message. We'd be more than happy to escalate a case on your behalf to a case specialist for further assistance.
Mark
Bought a new 2019 in September 2019, I just checked my oil at 5300 miles and there was almost no oil even on the dipstick, way past the low level. Had the oil changed at 1600 miles because it was recommend to remove any break-in debris. Not used to having to add quarts of oil between changes and was shocked to see it was that low after 3,700 miles and 60% oil life remaining. This is crazy, going to have the dealer do an oil consumption test after getting it changed tomorrow.
