Here is a link to leveling kit on the 13-18 with air suspension. I would assume we will get something similar for 19s
http://cftperformance.com/ram-air-lift-level-kit-front-links-only/
You can also have the dealer alter the ride height measurements with WiTech.
Interested in this too. From my impression and what I’ve heard the links are all that’s there. I have watched a video where they use the space and arm from another kit then the links. I hear the concern/worry is draining the air in the cylinder. The video I watched claimed 5 disconnects before a refill is needed.Any update on these kits coming out yet and working?
I made some links yesterday and they work fine but the ride do suffer a bit. The stock link on the back are 8mm. If you make your own links at 6.5mm, it will level the truck but the rear bounce around. So tomorrow I'm going to try to just raise the front to level with the rear. Leveling the rear to match the front is out of question now, I did not like the way the rear suspension felt. Also the measurement is from center of the ball socket to socket, not end to end.
New member here...
Has anyone installed the front leveling links? The ones I’m considering are from Revel Performance om google that are $199. Any help is much appreciated!
Hi, can you share your impressions, how you like it the ride whit the new links, if there is any changes? . ThanksJust installed links today
