BLKMOPAR
- Apr 8, 2018
The 4×4 Off-Road Package now stands alone and includes a one-inch suspension lift, with or without the available air suspension. Does anyone know how the 1" lift is achieved? Are they just adding spacers or are the actual components different? I would like to think the rear spring is taller rather than adding a 1" spacer on top. What happens if you add the Mopar 2" Fox kit at a later date? Will the truck sit 3" taller or are you replacing spacers with taller ones only to gain another inch? Can you even add the Mopar kit to the off-road package? Nothing worse than ordering something that may not be compatible with upgrades in the future. Air suspension is a perfect example because lift options are very limited and not worth the headaches. Any info on this topic would be greatly appreciated.
