LuckyWelds
I've been flipping through the suspension and wheel/tire Forums and have not found a sure fire answer.
I've run the size comparisons between stocks and the proposed setup that I'm looking at and it appears that it should fit but someone may have first hand experience.
The wheels are 20x10 -18
The tires are 35x12.25 which is approximately 318/60
Just off those specs alone in comparison to the factory 18s being : 18x8 +19
Stock Tires: 275/65
The proposed setup should be about 11mm further away from the suspension.
With the 3.5" RC lift/level has anyone seen any issues?
Stock Tires: 275/65
