Got these installed today, AMP Terrain Attack A/T A in 33/12.50 on stock 22-inch sport wheels. I was worried they’d rub but I have ZERO rubbing! My truck is leveled 2 inches with Readylift upper control arms. I should’ve mentioned this initially but I will say that clearance is pretty tight between the sidewall and UCA. I could barely fit a finger between the two but that gap is sufficient and will never change so its fine. I’m not sure if you’d have enough clearance with stock UCAs.
