Not the same, but I had 305/60R18 on both a non-ORP and ORP, but with aftermarket, +1mm offset wheels (vs +19mm for stock).Does anyone know if these will fit on a stock orp. I'm thinking the 12.2 width will be a problem
The shop said they thought they would rub, think I'm gonna go with 285 70 18 ridge grapplers which are about 34 by 11.5Did you ever figure out if these fit? I am looking at going with a 275-70-18 on my ORP
275 70 18 should not rub,they are supposed to be 33.2 x 10.8?The shop said they thought they would rub, think I'm gonna go with 285 70 18 ridge grapplers which are about 34 by 11.5
You will definitely be ok with those275 70 18 should not rub,they are supposed to be 33.2 x 10.8?
275/70R18 are OEM tires on the Rebel. They won't rub at all.275 70 18 should not rub,they are supposed to be 33.2 x 10.8?
