Nice dude. Looking forward to more pics.Saw a few pictures and decided to give it a shot.
Wheels are 24x10 fuel Mavericks +1 offset and the tires are 35x12.5x24. It’s raining today so I’ll get more pics when I can. View attachment 10060
I’m actually in the process of piecing together the same setup as you. I bought the ready lift 3.5 level and the same wheels and tires. I was hoping you could answer a few questions.
Did you have any rubbing?
What level are you running?
How do this tires ride and do they shake steering wheel? I bought the same brand tires.
Thanks
Looks awesome.I have the same set up but with the ready lift 3.5 and have no rubbing and no trimming.
I was wondering do you think with the ready lift 3.5inch lift could I fit 35x12.5x24 with a 24x12 -44 offset rim, I know I will have to trim alittle and stuff but just wanted another opinionSaw a few pictures and decided to give it a shot.
Do you think a -24 offset would run similar on a 3.5 lift?I have the same set up but with the ready lift 3.5 and have no rubbing and no trimming.
I was wanting to do the same thing but I've decided imma do 24x10 so I don't have to cut any metalI was wondering do you think with the ready lift 3.5inch lift could I fit 35x12.5x24 with a 24x12 -44 offset rim, I know I will have to trim alittle and stuff but just wanted another opinion
The rim height doesn’t matter, just width and offset. Search your rim info and tire size for other size rims and it will be very close. I say close because different brand and model tires of the same size (35x12.5x24 for example) may have a slightly wider shoulder or be slightly taller.Do you think a -24 offset would run similar on a 3.5 lift?
