2021 Ram Rebel Night Edition Wheel Offset
Mattiusmaximus1216
Menifee
Does anyone know the offset to the 2021 ram rebel night edition wheels? I currently have them on my rig and looking to change them out.
Looking to change out the wheels to 18x9 and want to keep the offset the same with the wheels flush or in the wheel well. Will be going to 35x12.5r18
Thanks
silverWS6
EPTX
19mm
Look around the forum some, if you plan on going with a bigger tire then you might need to get a different offset. The tire will rub the control arm, or come very close to it with some offsets.
Mattiusmaximus1216
Menifee
19mm
What offset would you recommend? I don’t want the tire sticking out past the wheel well. Thanks for the info!
scottmoyer
I'm running the TRX wheel with the stock Rebel tires and didn't have any issues with the same 19mm offset. The TRX wheels are 18x9, so your tires will be closer to the control arm. The size tire you're looking to go with will rub, so people are using 1/2" spacers (up to 2") on the TRX wheels to clear the control arms and the wheel well. The stock tires on the TRX wheels with 1.5" spacers gave my truck a great look, but I had to fine tune the wheel well due to slight rubbing.
silverWS6
EPTX
-12 is a pretty popular offset. That's what Im running and I have plenty of space.
silverWS6
EPTX
What wheel and tire size did you do? Also, Did you have to do any trimming?
Wheels are 18x9 -12 offset
Tires are 35x12.5
I just removed the small flap on the front, I have a 2.5 level up front. No trimming of the fender or liner, just pulled it back with some zipties as a precaution.
