2021 Ecodiesel 116k miles, engine internal failure!
flyingpoint
Hi forums,
My 2021 Ecodiesel currently has 11,600 miles on the odometer, everything is stock. It has always been serviced at the dealer. I also have the factory extended warranty—MaxCare 7-year/120k with a $200 deductible.
On 04/28, I brought it to a local Ram dealer for a leak. They diagnosed it as an upper timing cover leak, and told me it would be a warranty repair involving replacement of the drip o-ring and the cover.
On 05/07, I picked up the truck after the repair. However, the first thing I noticed was that the truck had a rough idle while sitting in the cabin. The next day, I brought it back to the dealer for a recheck.
The following day, the service advisor (SA) confirmed that the rough idle was abnormal and mentioned they found metal particles in the oil. As a result, the dealer needed to investigate further and file a new warranty claim with MaxCare.
As of today, I called the SA for an update. He told me they submitted the claim last Friday through their internal portal, requesting an engine replacement due to internal engine failure.
I asked the SA how long it would take for MaxCare to approve the claim and how long the overall repair would take, including the engine’s lead time. He said it typically takes about 4–5 days for approval, but it’s difficult to estimate the lead time for the engine to arrive. The actual replacement work would take about 3–4 business days.
I also asked if I could get a rental vehicle covered by FCA while waiting for approval, since I need transportation for work. He said FCA wouldn’t cover rental costs prior to the claim’s approval.
Does anyone have experience with this kind of situation?
  • Sad
Reactions: c3k
Hi forums,
Why is it going through MaxCare? Are you not still under the 5 year, 100,000 mile powertrain warranty?
It is 11,6000 on the odometer now which just beyond 100k miles mark.
Hi forums,
It is 116,000 miles on the odometer but not 11,600 miles. Thanks for @Dustin and @mikeru82 for the reminding.
Ah, ok. I was confused by the now corrected title and thought it only had 11,600 miles. Good thing you bought MaxCare.
Interesting that they found "metal in the oil" and curious how they determined that exactly. All engines' internals wear and dump a combination of metals in the oil, that's what Used Oil Analysis is good for. But those metals are usually microscopic and can only be determined with sophisticated analysis machines. Unless the dealer found metal in the oil clearly seen by the naked eye, I'm not sure how they arrived at that conclusion.
Anyway, keep us posted and good luck!
I have elevated aluminum in my oil. Found in blackstone's analysis. Thankfully, these EDs are notorious for that.. Was a little worried at first!
The service advisor (SA) didn’t disclose how they found the metal in the oil. They came up with that result within one day while my truck was in the shop. I assumed the metal had to be large enough to be visible to the naked eye.
Also, good news — the SA called this morning to say that FCA approved the engine replacement. However, he advised that I can start using a loaner car only after the parts arrive at the dealership.
I think the extended warranty is well worthy. At least mine has paid it all back.
