2020 REBEL TRANSFER CASE FLUID
2020REBEL
JUST DID MY FIRST SERVICE ON MY 2020 REBEL AND THE FLUID IS GRAY METALIC FLAKES.... FLUID I ORDERED FROMT THE DEALER IS RED... ANYONE ELSE HAVE THIS ISSUE??
Dusty1948
Rochester, New York
Depends on which transfer case you have:
48-11 On Demand requires 3.6 pints of 68049954AA
48-12
Part Time requires 2.7 pints of 68089195AA
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 17 July 2018. Now at: 029945 miles.
2020REBEL
48-12
Regards,
Dusty
2020REBEL
I know the fluid type I just found the fluid to be really metallic (there is some metal flake in the t case) just wonder if anyone else has run into this before??
RamCares
Michigan
Hi 2020REBEL,
If you are not able to determine a solution based on suggestions provided here, we recommend following up with your servicing dealer for further support with this inquiry!
Mark
RamCares
