Thought I’d add a towing update for my Gen 3 EcoDiesel. We just pulled our 6500 pound travel trailer up to Queen Wilhelmina State Park in AR with the Laramie EcoDiesel with 3.92 Rear end. The road to the park is a 13 mile long very steep, very winding stretch with everything from 55 MPH straightaways to 20 MPH swtichbacks. Elevation went from 1100 feet at the start to around 2700 feet at the top. The truck did fantastic, sitting in 4th or 5th gear most of the way on the steep sections with plenty of reserve power. Oil temp ran between 237-242 degrees and tranny temp never got above 194 degrees. The outside air temp was in the low 90s. The truck seemed to hang around 2500-3000 RPM, occasionally going to 4000 RPM momentarily when down shifting.
The trip up was from near sea level (166 feet) in Shreveport LA, so uphill most of the trip and I got around 12 MPG. The trip back was into a headwind and I also averaged 12 MPG.
We did the same tow a couple of years ago with my 2017 F150 with 5.0 and it had to work much harder, making the climb in 2nd gear, 4000+ RPM and trans temps over 220 (I had to pull over at one point to let it cool).
To say I’m impressed with the new EcoDiesel is an uderstatement. I’ve got just over 6000 miles on mine now and get excited every time I get behind the wheel. All of that low end torque makes towing so much more enjoyable and getting the trailer moving from a stop seem almost effortless.
