2019 rough MDS
Black_Pearl
Eastern NC
I have a 19 tradesman with the non etorque hemi and sometimes my switch back to 8 cylinders is very harsh to where the vibration turns into a slam that can be felt through the whole vehicle as if some bumped into the back of me. Most of the time it’s smoother, but I wouldn’t call it seamless. Averaging almost 22 mpg now, but am worries that harsh change is doing some damage to the drivetrain. Anyone else have harsh change when mds shuts off?
popcenator
Omaha, NE
My MDS transition was always very noticeable. I have it turned off in my tune but I never saw much of a difference anyway.
HeavyMetalHauler
Pretty normal in my experience. Half the time MDS kicks in and out smoothly and other times it’s exactly how you describe.
Black_Pearl
Eastern NC
Thanks everyone. With that said, it seems to be consensus that it’s okay to ride around with the gear limiter pegged to 8 all the time, right?
Rototerrier
That's what I do, otherwise I get the kick in the pants and the vroomf noise as it switched from 4 back to 8. Horrible system.
Lit_AF
Hardware Geek - Pro Detailer
Dubai, U.A.E.
Heard by doing so the lifters collapse after some rough driving.
How true is that ?
popcenator
Omaha, NE
How true is that ?
I did the same on my 2012 and never had a problem for the 80K miles I ran the tune. The earlier 4th gens had more of a problem with the lifters too. Neither this truck nor the 2012 were babied if that helps.
Rototerrier
How true is that ?
Way I figured it, Tow/Haul Mode does the same thing and I am towing about as often as I'm not. Therefor, I'm using the truck mostly as it is designed. If it's going to blow due to operating in this manner, then a truck used primarily for towing will do the same thing. I certainly wouldn't put it past RAM for having a design flaw, but I'll probably be out of this thing long before it blows.
2020GraniteBH
What kinda tune do you have and supporting mods to go along with it?
