I am also curious if anyone has done this with success? I called several dealers and they told me I should not try putting 2019 Rebel wheels & tires on my 2019 Limited which currently has 22s.
1.They said there isn't a safe amount of clearance for the calipers
2. They said the Rebel Tire 275/70R18 is 1" larger in diameter than my current 285/45R22's, so my speedometer would be off by several mph and you can't re-calibrate it
3. They also said my alignment would need to be redone even if I could get them to fit.
ThisCaliper size is the same on all the 1500’s.
You can have it recalibrated.
I don’t see why an alignment would be needed, you aren’t changing suspension components.
Best advice, find another dealer.
It wouldnt have to be rebel wheels. I just thought my 22s with the stock eagle touring tires wouldn't be ideal for western mountain minimum maintenance roads this fall. Would you just get different tires for the 22s or 20s with a different tire?Lots of parts, including the front spindles, have different part numbers for 22" tires. There are 2WD and 4WD suspension parts, coil and air suspension parts, regular, Off-Road Group, and Rebel parts. I was pretty surprised to see special numbers for 22" wheels. Marketing must have made quite a racket to get those wheels to the dealers. Separate parts for that small and relatively low take rate a feature are expensive.
The 18" wheels are a very tight fit to the brake caliper. It is quite possible the wheels won't clear it. I just did a quick test on the Black Rhino website, and for the Rebel, it only specs 20" replacement wheels.
My question is: why Rebel wheels? My not Method (used on the TRX), Black Rhino, etc. Far more options, IMHO better styling, and less expensive to boot.
BTW, to the OE wheels have a load rating on them?
We've run into similar washed out roads like your bottom 2 pictures and it would be nice to be able to get through that type of terrain. It only represents less than 1% of my total driving though. We spend 40 hours round trip on the highway getting to and from the mountains, so I don't want to get carried away with off road upgrades. I have air suspension and would like to just bolt on rims/tires that i could use in the fall hunting and for winter.How minimum maintenance and what did they consider the surface to be? What is your budget and is this a fun mod? What suspension do you have? I'm guessing not the ORG, do you have air suspension? If it just a dirt road that everyone travels in a passenger car you probably don't 'need' to do everything. If it looks like something usually run by logging trucks, maybe some more puncture resistance and lower air pressure are a good idea (just started a thread on in Off-Road on that topic).
So what do the roads look like and what is your budget?
View attachment 34296 View attachment 34297 View attachment 34298
