2019 Ram 1500 Rear Track Bar Bracket
wiendog
I am looking for a rear track bar adjusting bracket like that comes with the Mopar 2 inch lift kit for 2019 1500 4x4. Mopar does not sell alone.Any ideas.Thanks
The one in the MOPAR kit is not adjustable. It just raised the inner mounting point by 2”. I’m not sure why you’d want to do that with a non-lifted RAM ‍?
I am lifting my truck I just had to remove the Mopar kit from my truck it would not work correctly.I am going to replace with a readylift3.5 minus the preload spacer for a 2 inch front and back but would like to adjust the rear track bar though.
Why doesn’t ready lift include one? Seems like a poorly designed kit. I’m also curious why the MOPAR kit wouldn’t fit. Do you have the 6’ 4” bed? I’m still waiting to hear from someone regarding why dealers are telling people this. I installed the kit myself on my 5’7” bed and I can’t for the life of me figure out why it would work on the bigger bed.
I asked Ready Lift and they feel they do not need it.I just thought since Mopar designed the other that way I would like to use one.They decided from FCA after months of trying to make it work on my truck that it was not designed for a Quad Cab
I asked Ready Lift and they feel they do not need it.I just thought since Mopar designed the other that way I would like to use one.They decided from FCA after months of trying to make it work on my truck that it was not designed for a Quad Cab yes I have a 6'4" bed
I do have a 6 foot bed
Curious to know what wasn't working in regards to the Mopar lift.
The track bar relocation bracket probably isn't needed at that height. For reference, the track bar centers the rear differential. When you lift the rear, the differential will shift toward the frame mounted side. At 2" it will shift about 1/4-1/2 inch.
After install of the kit the ESC traction control kept engaging on curves and turns.It got elevated to the top FCA techs they replaced most of the sensors tried to recalibrate and ultimately after 3 months decided to eat my lift and now it is stock.Looking to try a ready lift 3.5 without the preload spacer and keep it to 2 inches front and back.I would like the track bar bracket though seeing as Mopar used it.
Strange. The lift should not have anything to do with the traction control. If that lift did, there is no reason to think the RL won't do the same thing. Why not try the new Bilsteins? They can do 2" like you want and are better than using a spacer. If for some kooky reason the same issues happen, drop them down to stock height and have a better than factory shock.
This is the most ridiculous explanation I’ve ever heard.
