Wobble and vibrations
ddonia
Is anyone experiencing a wobble in their 2019, usually at speeds over 50mph? At first I thought it might just be a wheel out of balance but it seems to come and go and is mostly present when the vehicle has been sitting for a while. For example, during the first drive in the morning after sitting overnight.
Also, I’m getting a terrible vibration in the gas pedal and floorboard. This primarily occurs between 1500-2000 RPMs. It’s really bad if I am in 4WD Auto, to the point where I just do not want to use that mode.
The vibration was not there when I first got the truck, but as I add miles it is getting worse. I currently have only 1800 miles on the truck....not cool for a $65k vehicle.
Have not been to the dealer yet but scheduling an appt soon. Just curious what others may have found or heard.
Thanks!
PS - it is a 2019 Limited with the 3.92 and eTorque.
Hey, sorry no one got back to u sooner.
I have the wobble, but not the pedal vibration. Lots of people in here seem to have that wobble at highway speeds.
You may want to check the forums menu and look for the forum that has TSBs and Warranty stuff. The forst pinned thread in that one covers a load of problems that FCA at least acknowledges.
See if your issue, or other issues, is one of them.
My trucks going in tomorrow and i am having them look at the wobble.
No worries, thank you. I did find the other threads a week or two ago. I brought my truck in for service and they found that the two front tires were bad so they replaced them. On the ride home all was good and smooth with regards to the wobble, but then the following day it was back as bad as ever.... I have not called the dealer yet to report this but will soon. Good luck with your repair! Would love to hear what they find. PS - the pedal vibration is still an issue too.
Thanks!
Good morning I am new to the forum but I have a 2019 Laramie with the standard rear end 321 and also noticing the problem up at highway speeds most of the shake feels to be in the gas pedal and not so much on the steering wheel did your dealer ever resolve anything for you? Thanks
Good morning I have a 2019 Ram Laramie will the standard 321 rear end I'm also having the exact same problem as there is a shake in the gas pedal in the floorboards at certain higher speeds I only have approximately 600 miles the truck's been into the dealer once and they couldn't find anything I was hoping you could shed some light on what they may have found feels to me like a driveline issue but would love some input.
I’ve had the problem for the last 5000 miles.
I have 14000 mile on mine. It use to drive smooth until the dealer had to replace my gas pedal. The new pedal transfers all kinds of vibrations from the engine, drive train, road and stereo. Also the truck developed a wobble/bounce/vibration through the whole truck. The dealer said everything is normal but how can it be normal when it didn’t do it to begin with. I’ve had so many issues with this truck since I bought it I’ve just gotten tired of the thing. I’ve been seriously looking at Toyota I’m tire of buying expensive garbage.The ram may look nice but the quality andreliability is in question for me. I don’t think i would ever buy a ram again. It’s sad because I really wanted to like the truck but with all the issues and no real fixes from Chrysler I feel in appreciated as a customer.
by the way my truck is 2019 Laramie crew 4wd with 3.92 rear.
Did you ever figure anytrhing out with this issue ? I know this is a little delayed but just curious. I have a 2019 Ram Rebel that is having the vibration issue.
Hi @Sfoster0717, we are sorry to hear that you are experiencing this concern. Please feel free to send our team a private message for support alongside your next dealer visit. We would be happy to connect you to a specialist as an additional layer of assistance throughout your vehicle service.
Kathryn
RamCares
Figured out what to do after a bad seam sealed weld leaking water in the front driverside of the cab, after a leaking rear window letting water run into the cab, the radio freezing a ridiculous amount of times, radio produces no music at all on multiple occasions, bad coil pack, vibration while driving certain speeds, banging in rear of truck. So I I sealed both leaks myself after the dealer magically couldnt find them, bought a hellwig sway bar and end links to fix the bang in the rear, still dealing with the radio issue, bought 6 brand new rims and tires along with all four new bilstien shocks, 3 different alignments and a dozen times at the tire shop checking with road force balancer still dealing with truck shaking, Tried lifting it then purchased 35'' cooper tires with 18'' fuel wheels and still have the vibration, truck does not sit at all so no flat spots in tires, I shut the MDS off everytime i put the truck in drive by pushing the tow haul button and or the gear selector trick, Truck has 30k on it has done the vibration since about 5000 miles cold or hot doesnt matter. Trade your POS in and buy something else, its ashame I loved this truck but WOW does it have issues. Ohh yeah and I tried the cold air intake and a tune as well just for the hell of it as one memeber said it got rid of his vibration I knew it wouldnt but figured it would be fun to see how the truck runs. Might as well buy a daewoo at least they were buy one get one free so you have a spare car when the turd is in the shop. I switched from driving fords for the past 18 years to this I may have had some issues with ford but nothing they couldnt fix. and not nearly as many problems with one truck
